I have a mobo with built in 2940u2w chipset and using the barracuda 180gb x 4 raid 5.. If I do 180x3, it boots up with no problem, but when I add in the forth drive, it hangs. do you think the adapter is having problem with the fourth drive in raid 5 format ?
when I do 2 mirror ie, 180x2 and 180x2 it comes up fine but not 180x4.
Do you think it's a limitation of my 2940u2w or the adaptec raid controller ?
