Ok I have a 9 gig 10,000 rpm cheetah in my case goin to waste
here is my problem
I have a Adaptec AHA-2940U/UW scsi card Only way I can get the HDD to boot is to have a bootable cd in the cdrom and be running win2k. When I finnaly get windows to boot up my scsi drive the one that I am booting from mind you shows up as E:.
Now I found this odd but it worked but my only problem is that I dont wanna run win2k on my gaming rig. Now I go and try to install win98 on it. Still same delima shows up as E:\ runs through the install fine after it reboots it wont come back up just goes to win98 splash screen and sticks.
So I say fine I just wont boot off of it, Ill just use it for storage and burning from scsi HDD to SCSI CDRW. I [plug in the HDD and windows 98 will not boot at all I unplug it win98 works fine.
I dont know if it is settings but I do have it set to device 0 on the scsi card that that is the id of the HDD. I know the drive works worked on my friends computer just seconds before we pulled it off. The card however has only been used for my cdroms.
I now have a scsi HDD not doin anything but giving me a headache any help would be appriciated. :\
here is my problem
