SCSI hard drives really hot.. what is the best cooling solution?
ucdnam
1,059
I have 2 fujitsu 10K rpm SCSI drives which create lots of heat. Even the metal of the case is getting hot.
What would you guys recommend for this situation? Any good HD coolers out there? These guys are so hot, my room is a lot hotter than any other in my place.
WalkingDead
1,103
Mount those drives in 5.25 bays with HDD adapters. 1 80mm 0r 92mm fan and 3M double sided tape. Mount the fan in the front of both drives. No need to spend big money on expensive HDD cooler.
