SCSI drive speeds!!!
Originally posted by: MS Dawn
It was there.
I need a real place to host images.
i feel you, i ended up getting my own domain name and webspace for ~$45/year just for these reasons. i am using host pc for $35/yr + a domain name and it has worked excellent - more than enough space and plenty of bandwidth 🙂
Can you check these boards diagrams and lemme know what you think of the functioning of PCI/PCI-X slots. On all these boards, they have two PCI/PCI-X slots sharing the same bus (if I am right) on all xeon boards and all slots run on ESB2 chipset alone. The AMD board has one PCI slot on one of the nVidia chipset and the AMD8132 is controlling the remaining PCI-X slots via its dual channels and has a seperate channel for SCSI, but the memory is DDR400 while xeon boards run on DDR2 667/533 memory.
H8DC8 Block Diagram
X7DA8 Block Diagram
X7DAL-E Block diagram
Any views on these boards??? which board do you guys think is best suited for reliable and fast PCI/PCI-X transfers without any delays??? I may be using atmost one LAN port that too for communicating with another system (not via ethernet/internet).
-Pavan
Here are my ATTO results...
Dell PWS 650
Dell PWS 670
They both are running on 15k U320 SCSI drives. The only difference is, 670 is using on-board Adaptec Controller with Fujitsu drive while 650 is using Adaptec PCI-X controller card with Seagate drive.
-Pavan.
Hi all, I have to decide b/n these 3 boards, help me out to choose the best one which can give me the best PCI/PCI-X data transfers and best HDD speeds 1) Supermicro X7DA3 2) Tyan K8WE 3) Supermicro H8DCi.... -Pavan
