Dont worry about the scroes against other drives especialy against IDE/UltraATA, You will never win because most of those are hypothetical, you need to find someone that has almost simulare setups to get RT benchmarks. eg I have a freind with a Ath xp1500 with Ultra133 drives and has a hard time beating the sandra benchmarks for the DMA33 but in reality we know its alot better.
In the older sandras I could beat there scores with my adaptec 3940uw w/UW drive on a K6-550 system but the newer sandra I cant come close using a Adaptec 29160 with a Qantum 10k LVD on that same system.
In sandra my scores with it claiming Windows cache off but claiming buffered (go figure)
buffered reads 62
seq reads 18
buffered writes 10
seq writes 17
access time 6ms
with Windows cache used only thing changed was
buff writes 55
access time went to 2ms (I dont belive this at all)
In the older sandras I was getting buffered and cached scores in the 250+megs so things have changed but I dont know what they are testing spacificly anymore wether its what windows sees or the hardware itself.
I would suspect your HD is working right with that score.
Make sure you are using a Ultra2.U160 cable not just UW/SE, The extra windings do make a difference.
Comment, You cant use SE cables on Ultra2 and LVD drives without the external terminator, Most (90%) of Ultra2 and LVD do not support internal termination and some U2/LVD drives will not work with a SE cable period.
I love my scsi.
