SCSI Cable and 68 to 80 pin converter question
dudleydocker
I have a Seagate Cheetah ST-118202 18.2 GB hard drive that I need a replacement cable for. The original cable also had a converter block that had the 4 pin power connector on it as well. My attempts to find a replacement on line have led only to confusion, and I won't even bother with the BestBuy/CompUSA's for obvious reasons. Oh to have a local computer shop again!
Can anyone enlighten me as to what I need to connect this drive to an Adaptec 19160 card?
Thanks.🙂
Try Blackbox (Blackbox.com I think). I had to get a SCSI cable, had no idea what I needed, called the tech and they helped me configure it over the phone-for free.
If you know what it is, though, I'm sure you can just order it online.
Eric
