Screen tearing WON'T go away... help!
shurleydude
32
For some odd reason, I'm only experiencing screen tearing in Q3A-based games, and I have turned v sync ON, but it does not seem to fix it. I also tried using refresh lock and that does not fix these screen tearing problems either. How do I fix them? And why do they only happen in Q3A based games? Thanks.
Rick67
475
Bring the console down (hit the ~ key) while at the game menu (not while playing) and type "r_swapinterval 1" and hit enter. Don't include the quotation markes. That should get rid of the tearing.
Rick67
475
BTW, you'll take a hit in the FPS department if you use this.
Also, you can add "seta r_swapinterval 1" to the config file located in your Q3 main folder. Use a program like word to edit it. Either way should work.
shurleydude
32
thanks!!!! oddly enough I really haven't taken any noticable drop in framerate, even with 2xAA on. It did fix my problems though! thank you VERY much! :)
