bulldawg1979
I've done a couple of system builds, but used very basic, inexpensive cases. This time I decided to treat myself to a better case, with the Antec P160, but discovered I'm stumped by some of the features. I'm used to drive bays that require screws on the sides of the drives to hold them in place and ground the drive. In this case, there are removable drive bays with rubber grommeted screw holes in the bottom of the bays. The manual says "mount your hard drive into the drive bay by threading the special screws through the bottom rubber grommets." There is a bag containing a variety of screws without identifying what is the "special screws." So, I don't know which screws to use AND I'm confused about securing the drive from the bottom screw holes. I'm going to use a couple of WD Raptors, so I'm going slowly and carefully in this install.
Also, the wires coming from the front of the case for firewire and USB are bundled and clipped together inside the case in such a way that it hard to identify which 10 pin connector plugs into the USB header vs Firewire. Is there a sure fire way to tell them apart?
Has anyone used this case that could give me some guidance?
Thanks,
Bulldawg1979
Thanks,
Bulldawg1979
