I just recieved my new 2.8ghz 800mhz FSB P4 and I installed the chip on the motherboard and took the heatsink\fan out of the box and noticed a small speck on the thermal interface material ( you know that gray stuff). So this being my first computer build I tried to dab it off with a soft cloth only I ended up rubbing off some of the gray material, not a lot just a little. I didn't know this stuff would come off. This speck turned out to be a bare spot where there was no material and now there is a thin line (thinner then a hair) of bare aluminum showing through the thermal material. I went ahead and installed the heatsink/fan but I havent powered up my new system yet.
Is this going to be a problem? should I get an RMA on this processor?
Thanks.
Thanks.
