- Dec 16, 2011
- 127
- 1
- 81
Hey guys I was told to come over this way for some help with some BSOD screens I got and what my memory frequencies should be at to get my system running as best as it can.
Fisrt my system is in my sig and I am now running 16gb of the same memory 4x4gb. I know its not the fastest thing in a box but it works well for my budget. I have the 4th core unlocked and am up to 3.2Ghz on the processor overclock.
I have had two BSOD mem dump screens when BF3 crashed when I had 8gb of memory. Have had problems with it crashing but never had these screens until a week ago or so. My novice self ordered another 8gb of memory thinking I needed more. Come to find out that more then likely is not the problem. So I ask you guys your opinion on the issue.
On the above issue I was told to check my memory frequencies and adjust accordingly the only problem is I am completely lost at this point. From what I can tell its 9-9-9-24? If that sounds right. Any help from anyone directly or if you can point me in the direction of some good reading material I am always up for learning on my own.
Thanks guys. I really want to get it running at peak efficiency!
Mark.
Mark.
