Sceptre 22" HD LCD monitor @Costco.com $299 AC/AR
videopho
4,185
29
Originally posted by: Ragnoros
Originally posted by: littlejim68
Looking at the Sceptre webpage they have a 24" comming out soon too. If thier 22" is such a great deal, I wonder how much thier 24" will cost?
Link
Fixed that for ya, also I believe This Is the LCD he was reffering to.
Myself, I want the 24" also. :p
I have a Dell 2405 and paid $750 for it. The newer 2407 can also be had for about the same or low $700ish or so. So I expect this to be priced at that range or lower. (at least let's hope so)
Vanditz
50
I called costco. This a online deal only. They don't even have this monitor in stock. I am thinking I will order this on Friday.
RossMAN
Grand Nagus
Feb 24, 2000
78,810
314
Yep I just received my CostCo coupon book and it's towards the back under the "valid only at CostCo.com" section :(
I'll probably order around the 21st after I see a few AT/FW/SD/AVS reviews.
polypterus
1,766
Do these on-line deals usually have shipping included? Their LCD shipping prices are all over the place, the Dell's are free, the 19" Spectre is $27 and the 20" is $17. :confused:
videopho
4,185
29
$17 shpping + ~ $25 tax + $300 = $342
Hmm...I have to rethink about this. Does buy.com have this?
I was too under assumption that Costco would carry it in store starting tomorrow or Friday the 13th?:evil:
Rockhound1
592
Still a pretty good deal. I wonder if you could order it on line for pick up at the local CostCo store to avoid shipping costs? Anyone know if this is possible?
By the way, I checked CostCo's Web site and they have taken down the page with this monitor.
videopho
4,185
29
Wonderful! So much for Costco this and Costco that...and now what we see on its site.
"We're sorry, this product is not available.11178163"
cyberkost
20,228
Dell 2007FPW sells for about the same price, but it's only 20". So if Sceptre has the same or better characteristics (which it does seem to have), better build quality (I'm not sure baout that), better design (I guess this is largely a matter of personal preference) then it's still a pretty good deal. To comment on the question of yours -- it does not seem that any other place has it at the moment.
AnotherGuy
678
Noppe Costko does not have it on the shops... i just checked today... Now all we need is some1 to review it and post it back on this thread
This 1 has hdmi in it while the 20" gamer does not have 1...
What u guys think about that Dell E207WFP comparing to this 1...
I cant find the details contrast... viewing angle... etc for that dell anywhere...
AnotherGuy
678
Also... Is there a way to buy this monitor from costco online if ur not a costco member...? Like a firend of mine is a member so maybe i can use their membership id to buy this monitor ??? Any ideas?
ThePhantom
137
@AnotherGuy: You can buy it online if you're not a member but you'd have to pay a 5% non-membership fee, which comes out to around $16. If he isn't buying one, I'd have him buy it for you.
cytoSiN
2,262
7
He doesn't have to buy it for you. Just ask if you can use his member number and then use your own payment form. And he can still buy one too that way. Costco membership is flexible like that. I use friends' or family members' cards when I go to B&M, then just use my own cash or amex (that's all they take at the store other than their own card, not sure about online), and it's never been a problem. Good luck.
Computergasm
243
Some cut and paste info:
x22wg-Gamer 22" 16:10
22" WSXGA+ (Gamer) LCD
High 1680 x 1050 resolution
High contrast 1200:1
Ultra Wide Screen Dual Page display*
Support DVI, VGA, HDMI(HDCP, 2nd DVI)
Headset & Microphone port
Support HD1080i/1080p,
LCD Panel
22" 16:10 wide WSXGA+ TFT LCD
473.76 mm x 296.1 mm Display Area
Display 16.7M colors
Ultra Wide Screen allow simultaneously
Resolutions
High WSXGA+ 1680x1050/60Hz,
1280x720/60Hz, 1024x768/60Hz
Brightness & Contrast Ratio
Brightness: 300 nit (cd/m²)
Ultra high Contrast ratio 1200:1
Response Time(GTG)
5ms
Viewing Angle
170º (horizontal)
160º (vertical)
Input Signal and Connector
VGA, DVI, HDMI (HDCP, 2nd DVI)
Audio In/Out
USB(2.0) x 2
Headset & Microphone jack on LCD Monitor
- convenient for MSN & Skype Desktop Users
User controls
Power on/off, OSD (On Screen Display), Contrast, Brightness, Clock, phase, H-Position, V-Position, Auto-adjust, Color Temperature, Audio Volume, Display Mode Detection(VGA & DVI) and Reset: Basic Setting. Features
Flicker and Static Free
PNP: DDC1/2B (Analog), DDC2B (Digital)
Less Than VLMF Radiation Standard
Panel & base detachable
Factory presetting mode: 40
Ergotron Arm Compatible (VESA 100mm)
Audio
In-Line Dual Stereo speakers with amplifier
(2.25 Watt /channel)
Power Source
60W max
100 to 240VAC @ 50/60 Hz
Certifications
CSA, FCC-B, ICES-003
Scanning Frequency
Analog: 24-82 kHz (H), 50-75 Hz (V)
Digital: 31-80 kHz (H), 50-75 Hz (V)
Size and weight
Gross Weight : 12.23 lbs Net Weight : 11.46 lbs
Dimension : 557mm(L) x 115mm(W) x 483mm(H)
22" Famous LCD Monitor Brand Comparison
Specifications
Sceptre 22" Viewsonic 22" Acer 22"
Model No. X22WG-Gamer VX2235wm AL2216wbd
Contrast 1200:1 700:1 700:1
Brightness 300cd/m² 280cd/m² 300cd/m²
DVI/VGA 1 / 1 1 / 1 1 / 1
HDMI Port (2nd DVI/HDCP) 1 none none
Response Time 5ms 5ms 5ms
USB Port 2 none none
Colors 16.7M 16.2M 16.2M
Viewing Angle (H/V Angle) 170/160º 170/160º 170/160º
Mic / Headset Jack
(convenient for SkyPe / MSN users) 1 / 1 none none
Built-in Speaker on LCD 2x2.25watt 2x2.25watt none
Stand/Neck Detachable (... by user) Yes none none
SuperSlim Bezel - Width* 0.595" 0.925" 0.925"
Hidden OSD Menu Key Buttons** Hidden keys with OSD Visible Visible
Rockhound1
592
Someone please post a review of this monitor after you get one. I would like to know your impressions about the monitor.
AnotherGuy
678
phantom ur the man if u give us ur first impresions... after some booting up.... gaming and half an hour general use :p
thnx for the info guys
