scanner software help
cpmer
I lost the disk to my scanner. Its visioneer 3300 flatbed scanner. It had drivers and software called paper port. Do i need this disk to still use my scanner? I tried going to the scanner folder under control panel in windows xp to try to set it up but it didnt work. I tried getting drivers from the internet but i dont think there for xp. Is there generic software i can use or am i pretty much screwed without the cd?
You can download the driver from here. Although this is not supposed to be XP compatible it can still be used since it is W2K compatible. Just click "Continue Anyway . ." when presented with this option during installation.
