Scanner Problems (Please Help)
Jubalek
Hi,
I just bought an HP ScanJet 2100C scanner. I have a win xp system and it is not working at all even though I installed the windows software. Can any one tell me where I can get a driver or sometype of program to use for the scanner? Thank you.
Tech Support
I ran into a similar problem with a HP scanner I used to have. Use the above link to troubleshoot your problem. It worked for me. Good luck to you.
