Scanner light burnt out...suggestions?
beverage
411
I have a visioneer 6100 USB scanner and recently the light burnt? out. Are the bulbs in scanners generally replaceable, or is it more trouble than it's worth to attempt to do so?
everman
11,288
Not sure if they're replacable or not...They usually aren't hard to get into though as I've opened some before which got stuck without a problem. These days you can get a pretty decent scanner for under 100 bucks or even around 50 (if you do mostly text and a few photos, nothing super high quality).
sharkeeper
10,886
Most use a form of CC. If you sub, just be sure to replace it with a natural "daylight" CC or your scans will look funky!
Cheers!
skatertech
85
Depending on the scanner, it can be a real pain to replace.
Just go buy a new scanner, it's a better deal.
