Hi,
The ScanJet 3400Cse is supposed to scan at 9600 dpi if I'm not mistaken
(please correct me if I'm wrong). For now, I can achieve only 1800 dpi.
So, if I enter a custom resolution of 2400 dpi in the box (I must type
it because the highest setting pre-avalaible is 1200 dpi), I have the
error message "Sorry, an error occurred saving to the file" when I hit "send
the scan".
1200 and 1800 dpi are ok, but if I try a number like 2000 dpi, I have
the same error.
It seems that my problem is related with the file size of the scan or with a
memory problem (like swapfile). I explain:
*With a swap file set as "Let Windows manage my swap file".
Scanning a 21,59cm by 29,72cm color photo at 100% scaling.
Settings: "Sharpen details in photo" and "Use maximum bit depth".
After the "Start the scan" message (done automatically at 200 dpi) I tried
the following optional adjustements:
Output type: "Best color photograph"
Resolution: 1200 dpi (selected in "custom resolution"
UNSUCCESSFUL
(message "There is not enough free disk space to save the scan).
*With a minimum swapfile set as 2000mb and no maximum:
Tried the same thing as above and I was SUCCESSFUL... but if I try 2400 dpi
(manually entered in the box because I don't have that preset) I have the
message "Sorry, an error as occured saving to the file. (File creator
error)".
But strangely if I set to 1830 dpi where the file size is 975 mb, it's ok.
Tried 1831 (976,8) and it failed.
To continue my investigation, I tried the following settings with the same
photograph:
Output type: "Black and white photograph"
Resolution: "2400 dpi" (size=559mb)
...SUCCESSFUL!!!
Tried 3100 dpi (size=933mb) and was successful again!!
...3200 dpi (size=994mb) and it didn't work.
So, I ask what could be my problem. I hope that the infos I gave you will
help you to find a solution.
Here's my complete computer setup:
Motherboard Abit Be6-II rev. 1.1 with Highpoint HPT366 ATA66 controller
(BEHXU BIOS)
Win98se
Quantum HDD lct10 20 gb on ide3 with hpt366 controller enabled
Plextor 8/4/32 on IDE2
Unknown cd 56x on IDE1
Sis6326 AGP card (with latest drivers) in AGP slot
Aopen NIC Aon-325 in slot 3 (sharing IRQ with HPT controllers)
Sblive value CT4830 in slot 2
GVC modem in slot 4
Epson Stylus Colr 400 printer on LPT1
ScanJet 3400Cse on LPT1
*HPT366 drivers are 1.28 beta
**Oh, I forgot to tell that I tried the USB setup and it's the same problem.
As anyone else ever experienced a similar problem and could help me.
Thank you.
Patrice Brousseau
the scan".
the same error.
UNSUCCESSFUL
error)".
photograph:
...SUCCESSFUL!!!
(BEHXU BIOS)
Win98se
GVC modem in slot 4
Thank you.
Patrice Brousseau
