I recently tried to reinstall my Canon CanoScan1240U Scanner (using a driver downloaded from the Canon Website) and a scanning utility program off of the original installation disk.
When trying to scan, I get the error "Could Not Select Twain Source".
Also when trying to use the original installation disk, I get the error "The Twain source is not present, so you will not be able to use the scanner even after installing the software".
I have tried uninstalling the software, running Regclean, deleting the .DS file from the windows Twain folder, rebooting with and without scanner unplugged etc but nothing seems to work.
Any help would be appreciated!
