Scaling problems with Catalyst 14.10 driver
Mazate
Hi there
I've just installed the 14.10 driver on Ubuntu and I'm having an issue. As is normal after installing the AMD video driver, the scaling is a bit off. Normally I open the catalyst control center and adjust the scaling so that it fits my screen and then I'm good to go from that point forward. I'm having that same issue now except the scaling option is virtually gone in the control center so I have no way to adjust this screen bigger to fit my monitor. It just gives me the option to "Scale image to full panel size" which is already selected by default. At the moment I have about an inch of black nothingness around my screen before getting to the bezel of my monitor. Any help is most appreciated.
Might have better luck asking around at the Ubuntu forums. I'm not sure how many people are running Ubuntu with an AMD card, but I'm willing to wager that someone has probably seen this issue over there.
I can't imagine that there would be a radical difference in control center options. I wish I could insert a screenshot here...
