sb-live and two cd-roms
What about the AUX input? Or does your SBLive have an internal AUX input? Making your own splitter may work, but back driving the unused CDROM's outputs may damage them - it depends on thier design.
I belive there is a splitter that plugs into the card that has two 4-pin connectors but am not sure. I'll check on the aux thing but didn't see one when installing cdrw. Anyone else?
if one of your cd-roms has a digital out, just use that straight to your sblive
and use the analog out for the other
Check this out. I have one DVD/CDR and one CDRW. I use the DVD/CDR as my main drive because it's the faster (40x) of the two. The audio out (4-pin connector) from the CDR is plugged into my soundcard.
Just last week, I put an audio CD into my CDRW by mistake...wasn't really looking at what I was doing. As it started to spin-up, I said to myself; "self, that was dumb, you'll prolly get an error message on screen and no sound!" Much to my surprise, it started playing just fine. I didn't know it, but I guess you don't need the 4-pin connector plugged in to get sound off a CDR drive. I don't know the tech explanation for this, but I can tell you that I couldn't tell the diff in sound B/T the two drives. Thought I'd throw this one in the mix.
<< I didn't know it, but I guess you don't need the 4-pin connector plugged in to get sound off a CDR drive >>
It's pulling the sound from the IDE cable like it does when you rip an audio CD.
