SB Live and KT7 problems
SuperMatty
12
I recently installed a fresh load of win2k with the latest SB Live drivers on my Abit KT7 system. Every now and then I hear "snap, crackle, pop" from my sound card during games, playing mp3s, etc. I have tried moving the card to different slots but it doesn't seem to help. I also have tried disabling ACPI to solve it and that hasn't worked either. And, I've also tried installing the newest VIA 4-in-1 driver which didn't solve the problem. Anyone know what the problem could be? It's not happening all the time but when it does it is annoying.
Techwhore
1,248
Someone had posted the same problem the other day. They seemed to suggest that there's problem with sb live! and via chipsets... said they weren't the only one having these problems... as for now, there's no way to correct it to my knowledge, but there better be soon, i'm buying a kt7 RAID and i want my sound
bobito20
29
I listed a post on this same problem the other day. I have the RAID version of your board, with the SBLive. This crackling has been frustrating me for about a week. I actually called ABIT to see what they suggested. Eventually, I got my crackling to diminish greatly, although I still have it once and a while (only about 1 crack every 15-20 minutes).
Here is what I did:
1) Download this latency fix and put it in your "StartUp" folder under the start menu (the readme explains) - This is a SB Latency fix, I don't think it matters if you have a Geforce video card or not:
http://www.geforcefaq.com/files/mvp3_latency12.zip
2) ABIT suggested that I enable the Memory Hole in the BIOS. This is under the advanced chipset features. This really didn't make a difference on my system.
3) Download the latest and greatest video and sound drivers. Depending on your video card, it might be an issue between the 2 cards.
4) I see that you installed the VIA 4 in 1 drivers. Did you do a full install of these drivers? One problem here is the UDMA option. If you installed UDMA, uninstall the drivers and try it again. To uninstall this option is sort of involved, and instructions to do it correcly are on VIA's website at http://www.via.com.tw/support/faq.htm, and look at the IDE Busmaster section.
5) And finally (you might not like this one), I bought an SB Live XGamer rather than the value (after testing my friends XGamer on my system and noticing that the crackling was considerably less). I don't really understand why this works, unless the revision of the card was different and something changed on the card. I have been led to believe that these cards are exactly the same. Well in my case, that wasn't true.
Hope this helps. I will continue to look for solutions, so I'll let you know if I find any.
PS - What video card are u using?
Bob
Mem
21,476
13
I have just installed a SBLIVE value(1024)on a KT133 board(MSI K7T PRO)there is no crackling noise,but I have heard of old SBLIVE cards having problems on newer boards.
TheNeck
431
I have the same problem only when i try to add a extra fan to cool down my system or when i connect an external fan to cool down my self. so i have to remove the fans, then remove sb live from device manager and then reboot. That is the only time i get that awful cracking noise.
also check out this site, very useful if you havea kt7 or ka7
Abit KT7/KA7
jimmygates
2,134
I got intermitten "popping" sounds from my SB Live. I got the SB Live retail version a long time ago. The popping sound doesn't just happen when I'm playing mp3's or games as I sometimes hear it when no sound is being played. For example, I could be reading post on this forum and I would hear a random "pop" from my speakers. I tried enabling 15M memory hole and disabling SB16 emulation to no avail. I have the ABIT KT7 w/ RAID and T-900mhz with Guillemot Geforce 32MB SDR. I also have the Sigma Designs decoder card which now gets kind of fuzzy, "shakey" picture when I played DVD's. I saw some people post this in Sigma Designs forum and I think they also have the KT7 board also. Hope this gets resolved.
-Jimbo
jimmybobob35
21
I also have experienced this popping and crackling from sblive card. I looked at all the forums I could find and there are so many different solutions. Look over at www.3dsoundsurge.com I fixed mine by updating my video card drivers. I have a C/L TNT2 ultra. 3.68 detonator drivers= popping and crackling. 5.22 detonator = no popping and crackling. strange??
bobito20
29
JimmyBobbob,
Where can you find those 5.22 drivers? My friend is having the popping problem with his CL TNT 2 Ultra. Thanks!
Bob
