SB 5100 problems
First off this modem worked fine for 6 months.....Then about 1 month ago my connection started to drop intermittently. Almost once an hr for no longer then 2 mins. I have had the cable company out twice. Both times they have remarked on how high my signal is. They added some splitters to knock down the signal but I still get dropped....help!
Here is the signal snapshot:
Downstream Value
Frequency 117000000 Hz Locked
Signal to Noise Ratio 28 dB
Power Level -7 dBmV
The Downstream Power Level reading is a snapshot taken at the time this page was requested. Please Reload/Refresh this Page for a new reading
Upstream Value
Channel ID 5
Frequency 26992000 Hz Ranged
Power Level 51 dBmV
Here are the logs from the 5100:
1970-01-04 23:21:00 4-Error 0x040D9A93 ToD request sent- No Response received
1970-01-04 01:15:13 3-Critical 0x04E33A74 Started Unicast Maintenance Ranging - No Response received - T3 time-out
1970-01-04 01:11:00 4-Error 0x040D9A93 ToD request sent- No Response received
1970-01-04 00:00:55 3-Critical 0x040D9A2C DHCP WARNING - Non-critical field invalid in response.
1970-01-04 00:00:50 3-Critical 0x04E33948 No Ranging Response received - T3 time-out
1970-01-04 00:00:47 4-Error 0x040D9A93 ToD request sent- No Response received
1970-01-03 22:01:23 3-Critical 0x04E33A74 Started Unicast Maintenance Ranging - No Response received - T3 time-out
1970-01-03 22:00:54 4-Error 0x040D9A93 ToD request sent- No Response received
1970-01-03 17:41:57 3-Critical 0x04E33A74 Started Unicast Maintenance Ranging - No Response received - T3 time-out
1970-01-03 17:40:54 4-Error 0x040D9A93 ToD request sent- No Response received
1970-01-03 03:52:26 3-Critical 0x04E33A74 Started Unicast Maintenance Ranging - No Response received - T3 time-out
1970-01-03 03:50:54 4-Error 0x040D9A93 ToD request sent- No Response received
1970-01-03 02:16:38 3-Critical 0x04E33A74 Started Unicast Maintenance Ranging - No Response received - T3 time-out
1970-01-03 02:15:54 4-Error 0x040D9A93 ToD request sent- No Response received
1970-01-03 00:00:49 3-Critical 0x040D9A2C DHCP WARNING - Non-critical field invalid in response.
1970-01-03 00:00:38 4-Error 0x040D9A93 ToD request sent- No Response received
1970-01-02 06:28:51 3-Critical 0x04E33A74 Started Unicast Maintenance Ranging - No Response received - T3 time-out
1970-01-02 06:25:44 4-Error 0x040D9A93 ToD request sent- No Response received
1970-01-02 02:42:01 3-Critical 0x04E33A74 Started Unicast Maintenance Ranging - No Response received - T3 time-out
1970-01-02 02:40:44 4-Error 0x040D9A93 ToD request sent- No Response received
1970-01-02 00:00:40 3-Critical 0x040D9A2C DHCP WARNING - Non-critical field invalid in response.
1970-01-02 00:00:29 3-Critical 0x04E33948 No Ranging Response received - T3 time-out
1970-01-02 00:00:24 4-Error 0x040D9A93 ToD request sent- No Response received
1970-01-01 23:50:23 3-Critical 0x04E33A74 Started Unicast Maintenance Ranging - No Response received - T3 time-out
1970-01-01 23:45:30 4-Error 0x040D9A93 ToD request sent- No Response received
1970-01-01 06:54:01 3-Critical 0x04E33A74 Started Unicast Maintenance Ranging - No Response received - T3 time-out
Downstream Value
Power Level -7 dBmV
Upstream Value
Channel ID 5
Power Level 51 dBmV
