- Jan 6, 2005
- 14,698
- 1,909
- 126
I currently own a gaming PC and a MAC G4, with seperate monitors for each.
I intend to upgrade my PC in the coming month, based around a GEFORCE 7800GT.
In making the upgrade, I want to get rid of the two seperate monitors on my desk and switch to an LCD. The LCD I have my eye on is the 20" Apple Cinema Display. I know others have pointed out that this is essentially the same panel as the Dell version, but I have had so many problems with Dell products, and their cheap build quality, that I do not intend to buy from them again.
That being said, the Apple tech specs state that to work on a PC, it has to be DVI compatible...as far as I can tell, the GEFORCE 7800GT has a DVI connector.
Is it possible to run both the PC system I will build and my G4 off the same monitor without having to switch the DVI connector from one system to the other...I know there are monitor splitters out there, but I also know that Apple hardware can be troublesome for such options.
Thoughts or recommendations?
