I just replaced a 20Gb Maxtor IDE HDD with an 80 Gb Seagate SATA Hard drive.
I ran this utility called DiskWizard (Startup Edition) to set up the drive for XP installation. It coppied files (for XP) and partitioned and formatted it and then displayed a message saying that I should now be able to restart with XP cd and boot and use the new drive.
My motherboard is the MSI K8T-Neo and comes with Floppies to install drivers for SATA. The instructions said to Press F6 in the beginning of Windows installation to install them which is what I did. There were a few options for drivers to install from the disk and I selected the appropriate one (Promise 378 for Win XP or something like that, no raid). So then I press Enter to continue the XP set up. After copying a few more files XP installation says that I do not have a disk drive available and asks me to restart.
I called Seagate and they told me that the drive is fine (since I was able to run the utility and copy files, format etc) and that the problem lies in my drivers, I explained exactly what I had done to the support person and he said I did everything as I was supposed to and that the only problem could be the drivers for my Onboard SATA.
My drivers came with my MOBO, I however went to the MSI website to see if I can find the newest drivers, but there was nothing for Serial ATA controller etc.
I have tried going through the whole process at least 3 times and every time once it comes to installing windows (after all the drivers), installation says that I do not have a hard disk available.
Any help will be GREATLY appreciated. I need to get this PC working today. Thanx.
