Hello everybody, im in desparate need of help.....again.
Problem:
I cannot perform fresh XP install with hitatchi sata drives.
The facts:
1. I have an ASUS A7N8X deluxe. Jumpers are properly set. Only the red cable is connected. There appears to be no other settings in the bios that i need to change.
2. I have two IDE drives also on this machine. I disconnected these drives while performing the fresh install.
3. I made the A: disk with the txtsetup.oem file and other proper files.
4. It appears that XP installed properly installed the drivers (pressing F6, etc)....everything is fine. I got a message like "installing Silicon image SiI...." on the blue screen.
Then the screen clears and the following message appears:
Setup did not find any hard disk drives installed on your computer.
Make sure any hard disk drives are poweredon adn properly connected to your computer and that any disk-related hardware configuration is correct. this may involve running a manufacturer-supplied diagnostic or setup program.
Setup cannot continue.
5. I tried the procedure again. Same, bloody error message.
If anybody could lend a hand, i would greatly appreciate the help.
Cheers!
Problem:
The facts:
Cheers!
