- Oct 28, 2004
- 49
- 0
- 0
I'm trying to install a single SATA harddrive, specifically a 250GB Maxtor 7200RPM SATA drive on an Soltek motherboard, model SL-K8AN2E-GR.
The drive shows up in Setup when I enter the BIOS, but does not show up when the SATA/Raid controller looks for it. I've tried a number of combinations:
I've set the SATA/RAID jumper (J2) to on to enable it. If I switch it, and I can't remember which, but on one setting it won't show up in the BIOS, and the other it will.
Even if the BIOS finds it, the SATA bios screen says there are no drive, but if I go into the RAID setup (F10 I think), then it'll either show up or not show up, depending if I've got the J2 set on or off.
The Maxtor boot CD doesn't do me any justice either, it only detects my EIDE harddrive.
As a side note, I also want to point out that FireFox will not load on my system anymore, it instantly crashes, nothing loads, nothing comes up, just the Netscape Agent pops up and says it crashed. However, Mozilla works, anyone know what might be up?
Here's a quick run down of my system specs:
AMD Athlon64 3700+ (2.41Ghz)
2GB PC3200 RAM
250GB Maxtor 7200RPM SATA Hdd
250GB Western Digital EIDE Hdd
DVD-RW Drive
ThermaltakeX Dasier V6000 (silve & blue) case
Soltek SL-K8AN2E-GR Motherboard
500 Watt PSU
Windows XP /w Service Pack 2, v.2096
DirectX 9.0c
2GB PC3200 RAM
DVD-RW Drive
500 Watt PSU
DirectX 9.0c
