Okay so I thought I had a K7V motherboard, but I have an Asus A7V motherbaord. Anyway, As I said before this is what my system has:
AMD 1ghz CPU
Asus A7V
768 RAM
Adaptec SCSI Card
Firewire Card
Ethernet Card
Video Card
Sound Card
And now I want to add this Promise Card. At one point it said "PCI Card in Slot 2 Share IRQ with Promise IDE Controller"
So Slot 2 doesn't seem to work even though I'm booting from SCSI which is in Slot 3 so I don't see the issue here. I updated the BIOS. Maybe I should update firmware for the SATA Card or something? Or do you guys think another slot will work?
this is from another post i made:
okay i tried 2 different ways just now:
sata card in Slot 2 with SCSI in slot 3
there's a shared IRQ with the onboard Promise Controller on the motherboard. It will stay on a black screen before the Windows XP screen is supposed to show off so basically a freeze
with SCSI in Slot 2 and sata in slot 3 it was saying insert boot disk before the XP screen is supposed to show up.
So does that mean I can't put anythin in slot 2 because of the stupid onboard Promise controller? that seems dumb.
Slot 1 has the soundcard. IRQ is shared with AGP Slot
Slot 2 is empty and shares IRQ with the ATA100 Promise controller
Slot 3 has the SCSI card and shares with onboard audio/amr
Slot 4 has Firewire card and shares with Slot 5 and onboard USB controller
Slot 5 has Ethernet card and shares with Slot 4 and onboard USB controller
Any ideas what I should try? In the Bios all the Slot IRQs are set to Auto
AMD 1ghz CPU
Asus A7V
768 RAM
Adaptec SCSI Card
Firewire Card
Ethernet Card
Video Card
Sound Card
