Sapphire Trixx reverting to default voltage after waking from S3 with HD 7950.
Ieat
260
Anyone else experience this? The overclock settings stay but the voltage returns to stock settings. Its a pain since it limits my OC and if I forget to reapply the voltage before gaming I get a driver crash. The correct voltage is applied after a cold boot or restart. Its just coming out of S3 that it reverts to the default voltage. I have the Sapphire 7950 with the reference 7970 pcb/cooler on it.
lopri
13,310
687
That happened with many video cards I used in the past. I believe they are supposed to work that way unless designed otherwise.
Ieat
260
Are you sure? I've never experienced this issue in the past when using Afterburner on other cards.
