Sapphire Radeon PCI-E x850 XT $105.63 After $20 rebate
Eeezee
http://www.newegg.com/Product/Product.asp?Item=N82E16814102688
And it's the new newegg, so you know the customer service is good
Brand SAPPHIRE
Model 100106L
Interface
Interface PCI Express x16
Chipset
Chipset Manufacturer ATI
GPU Radeon X850XT
PixelPipelines 16
Memory
Memory Size 256MB
Memory Interface 256-bit
Memory Type GDDR3
3D API
DirectX DirectX 9
OpenGL OpenGL 2.0
Ports
D-SUB 1
DVI 1
TV-Out HDTV/S-Video/Composite Out
VIVO No
General
Vista Ready Yes
Tuner None
RAMDAC 400 MHz
Max Resolution 2048x1536@85Hz
Cooler Heatsink and Fan
Operating Systems Supported Windows 2000/XP
Features
Features Full support for DirectX 9.0 and the latest OpenGL 2.0 functionality
SMARTSHADER HD technology
SMOOTHVISION HD technology
Packaging
Package Contents HDTV Cable
S-Video Cable
Composite Cable
Power Cable
DVI to VGA Adapter
S-Video to AV Adapter
Driver CD
Still can't beat this for price/performance.
Got one last month on the $30 rebate deal. ATItool fan control keeps the leaf-blower fan near silent at 5% most of the time, and the hot air blows out of the case. Only negs for me were the lack of VIVO and this sucker takes two slots.
great card, even greater price! Runs BF2 at max resolution (13xx by 10xx) no problem. all high setting, and getting average 70fps. compared to my old X800XL AGP, it's about 30% faster IMO.
Originally posted by: alent1234
i just bought a sapphire 1600XT from NewEgg earlier in the week for $111. Much better deal than this.
I don't know about "much better", if its even better at all. Paying more $$ for a slower card with newer features sounds more like a compromise to me.
my eyes hurt
looked at that chart on tuesday before i ordered and i swear the 1600 was better then than the 850
OK, looked it up and the big difference is that the 1600XT supports shader model 3 and the 850 is shader model 2
how much of an upgrade would this be from an old MSI Radeon X800 128MB DDR PCI Express x16? i can't seem to find a comparable card on that Tom's chart-- or is it slower than everything else on the chart!? :-S
These cards rock. Most will do PE speeds right out of the box.
Oh, and for whoever was asking, X850XT > X1600 so don't waste your money.
Originally posted by: WDEagle
Here's another Chart that might help.
hmm, seems like a pretty significant jump, but is it worth $100? i'm not a huge gamer, but i do like to play every once in a while...
thanks for the chart!
that exact card was $115 a week ago, no rebates. so its basically like a 13$ off deal. eitehr way its not a bad price for a good card. runs around the speed of a 7600gt, but w/o the new tech.
my eyes hurt
Yeah, that shader 3 does much to offset the 1600 getting 11fps when the X850 is pushing 48.
ha ha.
Why is this card (with a rebate) better than this card Look here for the same price with no rebate or this card Here that is only $4 more with rebate hassles. What am I missing?
Yes I know the one with rebate is "retail", but these are open box cards so you can't count on getting all the cables anyway.
It's better because it's new. IF this was an ATI refurb, it'd probably be safe. But Newegg's used items carry a considerable risk. (I.E. far lower standards for determining what is acceptable for a used item) Open box items are almost always cheaper then new.
Did you even look at it? Here is the path of the link:
Home > Open Box > Video Cards & Video Devices > Video Cards > Sapphire Technology Limited > Item #: N82E16814102688
All of them including the OP's, appear to be open box items.
