Sapphire r9 290 tri-X in Sharkoon mid case
I don't think the HDD cages are intentionally removable, from the looks of it, it looks permanent. If it is removable, you'll lose all of your HDD/SSD/Optical Drive cages. Terrible design.
Thanks. Finding a case is really tough since most names are slightly different according to the country. I hope this one will be good for the price.
Have you considered the cheaper Corsair 200R case? It's what I use and it can fit GPUs easily longer than 320mm. It can also be found for as cheap as $50 where I live, and the ability to fit up to 8x 120mm fans (4 of those can be 140mm as well).
Actually I am in luck since the carbide 300 r is on sale for only 8$ more. The store does not have the 200r though. Thanks for the tip!
