Sapphire 9600 Pro Overclocking
Scotboy35
Hi,
Can anyone help me with the overclocking of this card, it's supposed to be the 'Fireblade' and it does come with the Redline tweaking software but it doesn't seen to give me the option to up the speeds. I contacted the Sapphire Tech support and he says that I might have to wait until version 1.9 come out as ATI locks some of the cards. Is there any other program that will work for me ?
Thanks in advance
Based in Norway I think actually, seems to be where their stuff ships from.
Try downloading the Omega drivers (Omegacorner which I think unlocks the card and will allow you to overclock.
I still don't understand what you mean by the bios being locked. I have the Sapphire 9600 Pro card as well, and I had no problems overclocking it simply by using Rage3D Tweaker.
Yip I dont understand it, it came with the 'overclockerable' sticker on the box and as they included the Redline disc I thought it would be no problem. As I say I contacted Sapphire Tech support and they said the Redline doesn't work with all the cards and I would have to wait till a new version comes out. I am also confused.
