FAQdaworld
I have a weird situation with a mining rig and I'd like the guru's to help if they can 😀
MB : ASUS M4N98td EVO
PSU: Corsair 750
GFX Sapphire 7970 (http://www.newegg.com/Product/Product.aspx?Item=N82E16814202008
This rig is one of my primary miners and has been running perfectly fine for quite some time. It hasn't been overheating, and temps have been relatively stable at 74 deg c for quite some time.
This morning I checked on my workers and noticed that this system was down, which is unusual, this system in particular tends to be the most stable of the bunch. It was actually a fairly cool morning, so I know that it's not possible that the machine was overheating.
When I physically checked on the machine I saw it was powered down, hit the power switch and nothing happens :\
Pulled everything off of the mb and put it on a test bench. Nothing connected but the ram, cpu, monitor, and this one card. Jump the power, and still nothing :\
Put another gfx card in there and it powers right up and goes into my mining OS no problem. Put the original card back in and same thing wont power up at all.
Tried using the working card in primary slot and the questionable card in secondary, and still wont power up... Also tried with risers on the questionable card. If the riser ISNT powered, it will boot up, if the riser is powered I have the same problem (no power)
I assume that there must be a short in there somewhere but does anyone have any bright ideas or things I should try?
I cant RMA the card at this point 🙁
PSU: Corsair 750
