Saphire Radeon 9800 pro not recognizing AGP
KhanAlf
98
My rig:
-Asus A7N8X Rev 1007
-AMD Athalon 2700+
-1 Gig Corsair XMS PC3200 400 DDR
-Sapphire Radeon 9800 Pro
-Dell 1800 UltraSharp lcd
-Win XP Home
-Enermax 420 p/s
My Problem
I installed a Sapphire Radeon 9800 Pro in my machine back in April to replace an older ATI Radeon 9700 Pro AIW. I typically play online games and run average visual settings to compensate for any lag I encounter. So I have been happily gaming online until I go out and buy EQII, a very graphically intensive game.
As I try tweaking my settings, I find myself horribly laggy and decide to take a peak in my system. Sure enough, I notice a problem. My Ati catalyst drivers, in particular SmartGart, does not recognize AGP.
-First, I goto my bios enable both Fastwrite and AGP, check my agp aperature is set to 128megs. No change
-Secondly, I uninstall, reinstall my drivers. No change.
-I upgrade my bios to 1007, incase there were any old faulty bugs. No change.
I then try to run with smartgart installed, using ATI's faq. Instead of manually loading the drivers, I uninstalled them, then upon reboot, let winxp tell me there are new devices found and I direct them to the drivers. No change.
So, I reinstalled the latest drivers. I then, removed the video card and reset it back in the agp slot. No change.
I am at a loss and after 4hours of creative thinking, I am drawing a blank. The solution is probably very simple but I must be overlooking it. Anyone offer any advice?[
MrChad
13,507
Have you installed your nForce chipset drivers? Try reinstalling those.
KhanAlf
98
Holy fast response Batman, did you just respond in 10 secs!?
Gunna check that now, will post back asap. Thanks for uncannily rapid answer
Mem
21,476
13
Did you try reinstalling the Nvidia AGP driver(Gart),I would also try Driver Cleaner and fresh download of ATI 4.10s from here .
Driver Cleaner (Note: follow the "readme file" instructions and run in safe mode) .
Btw if you go with the new CCC(44.2MB download) version you need Net Framework 1.1 installed.
MrChad
13,507
LOL, must have visited this forum at just the right time I guess. :p
KhanAlf
98
Installing the nForce chipset drivers seems to have done the trick. Both dxdiag and catalyst drivers seem to recognize it now. Thank you -very- much for your help. I am gunna install the 4.10's now per Mem's advice after cleaning out my drivers. Thank you both again for pinpointing the problem so quickly. Goes to show, it's a huge learning process b/c I would have never thought of that :)
