So I finally upgraded my old 128mg A6600 to a new 512mg 3650 card. But somethging isn't quite right.
In the cards utility page it shows the cards GPU/Memory speed but I can't change them...
In one areaof the utility it shows the GPU speed can be moved from 725-750 and it's set at 725...
The Memory speed can be moved from 400-500 and is set at 400.
If I try to move either one even the slightest bit it won't accept the change and just goes back to 725/400
Then just below it in another window it shows the current values.
The GPU says 300 and the Memory shows 400.
Huh....
The mobo is a Asus P4PE and my AGP speed is set at 4X but why can't I get a little more out of it. I have yet to run any games or apps as I just did a complete fdisk and started all over last weekend. Only thing loaded is OS XP pro, my mobo and vidoe carddrivers.
I also loaded the latest 9.1 catalyst drivers.
Any help..
Any help..
