Santa Cruz WinXP 4 Channel Problem
xizor
I have this very strange problem with WinXP. I'm using the 2 most recent set of XP drivers and sound is only playing on 3 of my 4 speakers. In WinDVD 3.0 and Winamp sound will come on and off on the rear/left speaker sporatically. The speaker is fine itself, but none of the speaker presets 4 speaker or 5.1 work at all. Anyone know an option or driver that I can use to make them all work correctly in XP?
xizor
Are you using the drivers from Voyetra's site? Make sure all your cables are plugged in correctly on the back of your speakers. Check to see if you have any interference around the speakers. Hope this helps.
