- Jun 30, 2004
- 16,822
- 2,143
- 126
For years now, I've tried to reduce "impulse buying."
We're trying to cut energy consumption in the house. Mom's old MGA TV is now about 20 years old, but just keeps on ticking with a stellar (analog) picture. She leaves the TV on all the time -- forgets to turn it off when retiring for the night.
Meanwhile, I'd finally put myself firmly in the HDTV - Media Center - large-screen consumer-group. Great success with a 42" LED-LCD LG model and a SiliconDust HomeRun PRIME. The silly-cone and cable-card now makes it possible to give mom HDTV with the spare (and only) HD-cable-box. The other cable-boxes are SD-digital.
Mom's "room" is the family den -- a pretty small room. She is absolutely insistent that the new HDTV must fit in an oak cabinet which has a "TV" shelf 28" wide. So I started looking for a 1080p LED-LCD HDTV that is either 24" or 26" -- (32" just might not fit . .
There are fewer offerings for smaller HDTVs, and among the few -- only a smattering of brands you might feel comfortable with -- for instance, Samsung and Toshiba. I settled on a Toshiba which had bad reviews for "tinny" audio, and planned to get a cheap 2.1 speaker system for it.
Went to WalMart where the Toshiba was supposed to be in inventory. It wasn't there. The floor salesman directed my attention to a SANSUI LED-LCD 1080p 24" unit. I was surprised at the picture clarity, and the audio was quite acceptable. I found later that the audio was touted in the few customer-reviews I was able to locate.
Sansui had been a top-shelf maker of hi-fi and audio equipment back in the '80s, maybe earlier. I think they started producing low-end TVs back in the '90s, and their orientation was a "mass-market." The TV at WalMart was $10 less than the Toshiba model I mentioned.
Got it home; set it up. Everybody is happy with it in that little room. Of the maybe 10 reviews I could find, the reviewers are also "mostly happy" with the unit.
I'm wondering if I should worry about the unit's lifespan or longevity. If there are warranty troubles or the warranty expires, the $180 I spent is not a major loss -- provided I can find a BETTER 24" or 26" unit to replace it. On the other hand, these small unit options seem to be shrinking.
Sure seems like a nice TV, though . . . . for the room in which it's located and its usage . . .
