Sandra not reading correctly??
H4rm
I have an Abit KT7-Raid motherboard, 1 ghz Socket A T-bird, PC150mhz Mushkin HSDRAM, and Sparkle 300 w Pwr supply. After having run Sandra Pro on win98 and Win Millenium, my FSB reads 100 mhz? It should read 133 or 150 mhz right? I do have Host+PCIclk enabled in the Bios. Why wont Sandra read this correctly, and how do i fix this or is there another software that will give me good readings on my ram speed or FSB speed?
Sandra is reading the front side bus correctly. Athlon's use a 100mhz bus the via chipset will add 33mhz to the memory bus if you tell it to and you have memory that can handel it. You can change you bus speed under the cpu options in the bios but that would be over clockin your cpu. I have a 800mhz over clocked the bus to 112 + 1 = 113 x 8 = 904. If you over clock your mileage may vary there's lots of info on the forums on over clocking you should go through it your inclined to do so.
