Hi,
1st time sandboxer here.
I've been reading how vulnerable win xp is now compared to vista/7 so I wanted to add another level of protection until upgrading. Though I might leave xp on my 2nd box. I run 2 hds a 640gb with 2 partitions (DRIVE C & D) and a 2TB storage drive (DRIVE E). Drive C is my os/programs drive and I set up DRIVE D as a sandbox and using it as my download folder.
Is this a good idea or should I set it up differently?
Do I need to set up programs that may use these files in that folder? Will it make them run slow or not work? I ask because it seems best to have vlc player, firefox, adobe, flash, etc., opening in the sandbox so that if anything gets infected it doesn't get to crucial system files.
My general build:
e7200 dual core
4 gigs DDR2
XP pro sp3
Firefox with adblock (anything else I should add)
Planning to add a 2nd browser in the sandbox if it will help.
Got rid of Adobe and will update to adobe 10 asap.
Malewarebytes updated and scanned every few days or whenever.
AVG 2011 free
Windows firewall
Any other recommendations.
TIA!
My general build:
e7200 dual core
4 gigs DDR2
XP pro sp3
AVG 2011 free
Windows firewall
TIA!
