Samsung Syncmaster 950p monitor owners, help a brother out?
Balt
12,673
482
My monitor is either failing or has had it's settings screwed up. Everything appears rather blurry. Unfortunately, the reset/recall function no longer works.
My question is: What settings do you have for "Focus"? It is on the Screen menu.
Thanks in advance. :(
Note to mods: Posted this here because it's not really technical and I think there are probably more 950p owners that peruse this area of the forum.
flexy
8,464
155
hmmmmmm...for my desktop i have
64
28
mine is rather old too and i think it shwos it age...stuff getting a bit blurry...focus does not really help..but you can try experimenting
edit: yes..screen menu
Balt
12,673
482
Not seeing much difference, unfortunately. It is probably as you say, it's just showing its age.
Thanks for you help, though. ;)
