Samsung SyncMaster 912N is a 19-inch analog TFT-LCD
funboy6942
15,368
418
Linkage
The Samsung SyncMaster 912N is a 19-inch analog TFT-LCD delivering a 800:1 contrast ratio, 260 cd/m2 brightness, 1280 x 1024 resolution, 170/170 degree viewing angle and scanning frequency of 30-81 kHz horizontal and 56-75 Hz vertical. It features a narrow bezel design, built-in power and Samsung?s MagicBrightTM and MagicTuneTM technology.
Specifications
Model 912N-Black
Panel Type a-si TFT/PVA
Size 19"
Pixel Pitch (mm) 0.294
Brightness 260 cd/m 2
Contrast Ratio 800:1
Viewing Angle (H/V) 170/170
Response Time (ms) 25
Aspect Ratio 4:3
Interface Analog
Frequency Horiz. Rate (kHz) 30-81 (Analog)
Vert. Rate (Hz) 56-75
Bandwidth (Mhz) 140
Resolution Native 1280x1024
Colors Supported 16.7 Million
Signal Input Input Video Signal Analog RGB
Sync Type Separate H/V, Composite H/V, SOG
Input Connectors 15pin D-Sub
Plug and Play DDC 2B
Power On/Working (Watts) 38
Wall Mount VESA® 100mm (optional)
Cabinet Color Front/Back Black
Available Colors Black
Dimensions (W*H*D) Physical (inches) 16.4 x 16.7 x 7.5
Packaging (inches) 20.0 x 19.4 x 5.9
Net Weight Physical 12.1 lbs
Packaging 16.5 lbs
Features Special Built-in Power Supply, Narrow Bezel, MagicTune TM , MagicBright TM
Included
Warranty Parts/Labor/Backlight (yrs) 3/3/3
k1114
1,153
Samsung has a nice policy on no dead pixels and the contrast ratio is good, but the brightness leaves a lot to be desired and I could never see dumping $400 on a 25ms response time LCD, especially without DVI.
I'd rate this room temp at best.
IGBT
17,976
141
..thanks for the info..is this a current model?? no dvi..25ms..might be an older model and the price may soften up even more.
styrafoam
2,684
910t is $10 more after a $30 mail in rebate. Specs are similar, not quite identicle although the 910t has DVI.
NiKeFiDO
3,901
Because it is a PVA panel, this monitor is not for gaming, but has awesome (relative to other LCDs) color reproduction (8-bit panel with PVA picture quality). I would def go for the 910T however.
alrocky
1,771
The 912N has hovered around $400 the last couple of months. CompUSA had it for $380 AR on Black Friday (Thanksgiving +1) and now lists it for $400. CircuitCity lists it for $380 AR. Of course the OP's linked site offers the benefit free shipping and no tax.
The 910T mentioned by styrafoam is tempting and a quick check looks like Newegg has the best price; I likes that free FedEx shipping. Just with I didn't have to pay instate tax. Amazon shows the silver @ $496.59 and the black @ $469.98. Hmm, the $30 rebate is good until the end of the month.
bigpow
2,372
Wait for 913N, it's just around the corner (I believe it's available outside US)
A lot faster (8ms) but still no digital in.
