- Jul 17, 2002
- 2
- 0
- 0
The Samsung SyncMaster 760V 17" LCD Monitor is currently on sale at Amazon.com. They sell it for $589.49 - $50 Mail-in-Rebate = $539.49. (Purchase cuttoff date for rebate to be effective is July 31st.) Here's the direct link:
SyncMaster 760V
The specs are as follows:
Compatibility: PC
Panel type: TFT LCD
Diagonal viewable screen size: 17 inches
Dot pitch: 0.264 millimeters
Contrast ratio: 400:1
Glass surface: Information unavailable
Horizontal viewing angle: 150 degrees
Vertical viewing angle: 130 degrees
Light source: Information unavailable
Response time: Information unavailable
Brightness: Information unavailable
Input signals: Analog RGB
Input connector/cable: 15 Pin Mini D-sub Male
Maximum noninterlaced resolution: 1280 x 1024
Horizontal frequency: 30 to 81 kHz
Vertical frequency: 56 to 85 Hz
Maximum display area: Information unavailable
Power on/off: Yes
Keys: Information unavailable
Left/right: Information unavailable
Contrast: Information unavailable
Horizontal/vertical position: Information unavailable
Horizontal/vertical size: Information unavailable
Color temperature: Information unavailable
Language select: Information unavailable
Display frequency: Information unavailable
Auto adjust: Yes
Backlight control: Information unavailable
Recall: Information unavailable
Width: 18.2 inches
Height: 17.3 inches
Depth: 7.2 inches
Weight: Information unavailable
Warranty, parts: 3 years
Warranty, labor: 3 years
Only bad part is that it doesn't have a digital input. Otherwise, I think it's a good deal.
SyncMaster 760V
Compatibility: PC
Panel type: TFT LCD
Power on/off: Yes
Auto adjust: Yes
Width: 18.2 inches
Height: 17.3 inches
Depth: 7.2 inches
