- Oct 11, 2004
- 60
- 0
- 0
Originally posted by: Lurker1
Try $112.99 @ ZZF for the 750s. Sounds like a better deal, not to mention that the 1TBs seem to have been having problems.
It would be helpful if you could list some good sources/forums as to the problems theyre having. So educated readers have an idea of what to expect.
So to start, Newegg user reviews: http://www.newegg.com/Product/...x?Item=N82E16822152102
And I'm hoping they fix things quickly... I really wanna stick a dozen of these in my server...
Originally posted by: cmv
I read those reviews a while ago and it looks like the problems are:
1) NCQ + Nvidia chipset == disable NCQ
2) some harddrive check utility from Samsung + drive = incorrect results == don't use util
3) SATA300 + some mobos = problems == set jumper to SATA150 on drive
Is your server using Nvidia chipset? If so, WTF! If not, what are you waiting for? Sure the utility issue is lame but if they work with SMART than everything should be fine (assuming you use backups as after all one thing is true no matter what: all hard drives suck).
Originally posted by: Genx87
If you use an Nvidia chipset, I suggest using the built in microsoft drivers. Their controller drivers have issues in my experience.
NCQ work with the Microsoft drivers on the nForce (3)?
