Samsung Magician - OS Optimization question
BonzaiDuck
15,877
1,548
Upgraded Samsung Magician to the newest version, and couldn't keep it from starting on boot.
Appearently it is now added as a scheduled task that is executed on start as opposed to registering as a regular startup service/program.
It can be found by running Taskschd.msc and it should be in the main task folder. I simply disabled it, and it seems to work.
Well . . . then there's nothing to prevent putting it in the taskbar as a "Quick Start," deleting the task schedule option . . . and . . . good to go . .
If you want to cache any RAID array, you could uninstall Magician and install Primo-Cache or Super-Cache. The only difference: they both provide static allocation of RAM -- an amount you choose. Plenty of options with that. Lord knows how a good hardware controller might respond to the program -- or register in a benchmark, that is . . . Maybe check again, but I don't think those programs had any restriction on the SATA BIOS mode. Worth investigating.
So like the unruly teenager on Jerry Springer says, "Whatevah -- whatevah -- you can do what you want -- whatevah!!"
Coup27
2,140
Removing it from startup does not suppress Samsung Magician from starting up though, so I'm not sure what SamsungRapidApp.exe actually does.
I haven't refreshed myself with all of this thread but SamsungRapidApp.exe is part of RAPID. If you enable RAPID from Magician, it launches two services on boot up with the above being one of them. It is those services which cache your files and act as a link between Windows and the SSD when RAPID is activated.
If you don't want Magician to launch on boot you need to remove it from task scheduler. Magician does not need to launch to use RAPID.
OddRamos
9
Since googling about Samsung Magician Advanced OS Optimization leads to this thread, I'll add some points here.
Samsung Magician has some translation imperfections, which makes some settings in Samsung Magician hard to understand (incomprehensible), especially in OS Optimization – Advanced tab.
An easy way to understand how buttons in Samsung Magician Advanced tab work is to enable hidden system files, go to the root of system C drive, and look at creation and deletion of hiberfil.sys file when Hibernation Mode is activated or deactivated in Samsung Magician Advanced tab.
1. You can Apply Maximum Performance, Maximum Capacity, Maximum Reliability tabs and see what functions were activated or deactivated in Advanced tab. Advanced tab uses a little bit awkward style by showing the opposite of the current status, i.e. Activate means that currently this feature is deactivated and Deactivate means that the feature is currently activated.
2. Changes that you make in Advanced tab by pressing Activate or Deactivate buttons are instant and don’t require pressing Apply All button. For instance, pressing Activate button of Hibernation Mode instantly creates hiberfil.sys in the root of system C drive and button name is changed to Deactivate. On the other hand, pressing Deactivate button, instantly removes hiberfil.sys from the root of system C drive and button name is changed to Activate.
3. You don’t need to press and you shouldn’t press Apply All button in Advanced tab once you finish manually settings the features, because it changes the values to default ones designed by the developers, for instance it Activates (button name is changed to Deactivate) Hibernation Mode.
4. If the combination of settings that you’ve made in Samsung Magician Advanced tab is the same as predefined modes in Apply Maximum Performance, Maximum Capacity or Maximum Reliability tabs, Current Status: name will be changed from Advanced to that particular mode name.
5. In Samsung Magician Advanced OS Optimization:
"Deactivate" button deactivates Prefetch / Superfetch.
"Activate" button activates Prefetch / Superfetch.
For SSDs Prefetch / Superfetch should be disabled.
Here is how you can check that the Superfetch is really disabled in Windows:
Open Run dialog (Win + R) - Type services.msc + Enter to open the Services Manager - Scroll down to Superfetch service - Double-click on it to open it Properties box - The startup type should be Disabled.
Example showing how to interpret Samsung Magician Advanced tab settings:
Buttons are showing the opposite status of the current state. Clicking the button will set it to the state that it is showing. Currently the settings shown in the image mean this:
Hibernation Mode: OFF
Indexing Service: OFF
Prefetch: OFF
Write Cache Buffer: ON
Write-Cache Buffer Flushing: ON
johnpombrio
64
OK, the answer to the OP post is to Deactivate the Prefetch/superfetch button so that the Magician reads Activate. The Superfetch is disabled when the Activate button is showing in the Magician software. The screenshot by Odd Ramos is what you should see for a properly set Advanced settings.
