Originally posted by: Capt Caveman
Originally posted by: WaTaGuMp
Originally posted by: kac1
Thanks for the reply capt caveman. I noticed that in your sig you have the samsung 204b..how do you like it?
I had one and hated it, poor viewing angles meant the slightest movement and you saw the difference, backlight bleeding along the bottom was a huge line noticable gaming for my unit, also screen uniformity was poor.
A couple of minor annoyances but nothing that would stop me from recommending it. The screen is very bright(too bright) and the color is excellent. It doesn't have the viewing angles that my HP L2335 does but I only notice it if I'm standing above it or if I purposely try and look at it from an angle. Looking at it straight on, like you normally would, the limited viewing angle issue is a moot point.
My unit has a slight backlight bleed at the top but b/c the default brightness of the monitor is so bright, when I turned it down to Internet(the monitor has profiles with different brightness/contrast settings), no backlight bleed.
Note I bought this monitor as a secondary monitor in a dual monitor set-up. I bought it for $284 AR and it's excellent for the price.
