Why did you settled on those 2 systems? Why vacuum tubes?
What is your budget?
What are your priorities, sound quality? wife acceptance factor? look? size?
I think you can do much better than the 2 systems you listed and people will be more than happy to make some recommendations for you once we know what your priorities are.
these are the only topend systems in my country(india)
and yes sound quality is the factor,samsun claims its system to be 7.1 ch
is it true? on connectivity both are the same i guess while the sony has additional nfc.
glass fiber tech vs magnetic fluid tech.?
subwoofer performance?
will vaccume tube amplifiers really make a bigg difference in sound quality?
and i hear that sony is much preferable when it comes to sound quality..
looks not a matter
