Samsung HDTV problem
Dorkenstein
3,554
My cousin was over here playing Gran Turismo on my ps2 and it looked excellent. After turning it off and leaving we came back a few hours later and turned it on again. The color and graphics looked significantly bad. What can cause this, should I be concerned, and how do I fix it? Thanks.
hans030390
7,326
you broke the tv by neglecting it.
um....try reconnecting the cords if you havent...try other cords, and is this GT4? if so, mess with the video settings (pro-scan, etc)
Dorkenstein
3,554
There is a very loud click on turning it off and on that was never there. Thankfully I have a 4 year replacement plan on it and I can get it fixed.
HDTVMan
Banned
Apr 28, 2005
1,534
Coonect a DVD player through the component inputs and see if the color is still bad or try cable/sat and see if the color is bad. That will narrow it down to the tuner/SVHS/Component inputs or the PS2.
Good luck in getting it fixed whatever it is.
