86waterpumper
Hi, I am setting up a computer for my daughter to use, and play games on etc. I put a 500gb f3 spinpoint on it. I let windows format the drive, and installed win 7, and then a bunch of update. I decided after the fact that I may as well short stroke the drive to keep the speed high, because there is no way she is going to need all 500gb. Windows allowed me to adjust the partition down to 240gb, so basically half the drive.
Now my question is, from reading around the net some say that the method I used is not short stroking and some do. Do you have to use a 3rd party software to completely disable the unallocated space or is the method I used effective? This is a single platter drive, so all you are doing is keeping data off of the inner tracks so that the drive speed does not degrade as it fills correct? I know that using 1/4 of the drive is the better method, but I had really rather not reinstall if I don't have to.
