Samsung Exy 7420 Benchmarks Reveals Superfast Mobile Chip
Status
Not open for further replies.
Jan 6, 2015
25
The Samsung Exynos 7420 chipset has been tested in the Geekbench 3 benchmark, likely residing in a prototype Galaxy S6 unit. The SoC aced the benchmark test scoring 5478 and 1520 points in the multi-core and single-core tests, respectively.
First benchmarks of Samsung Exynos 7420 64-bit 14nm (unconfirmed) chip as benchmarked and compared to new Intel Cherryview 14nm mobile:
http://browser.primatelabs.com/geekbench3/compare/1754567?baseline=1780313
Intel Cherryview Single: 837 Samsung Exynos 7420: 1520
Intel Cherryview Multi: 2817 Samsung Exynos Multi: 5478
http://www.gsmarena.com/samsung_exynos_7420_aces_geekbench_30-news-10921.php
Duplicate posts are not allowed.
Markfw900
liahos1
573
45
geoxile
327
25
Not as good as I was hoping considering Apple will undoubtedly have a new SoC ready soon as well.
Also, this seems to coincide with the 1.2x boost ARM predicted for their A57 running in 64-bit workloads (vs 32-bit). The Exynos 5433 could score around 1250 to 1300 points in single thread tests.
witeken
3,899
193
Afraid to compare to Broadwell, aren't you? Atom is still in its infancy: the architecture you're comparing your Samsung chip with is from 2013 and only the first iteration of Atom.
dahorns
550
83
To be fair, it kills Core M in multi-core. It actually scores the same as many of the u series of Core. Of course, a lot of that is due to the SHA score. And I don't actually believe these processors perform anywhere near Core M or an I5 u series.
That being said, no doubt this thing crushes Bay Trail. As for Cherryview, I'm going to assume that bench is no where near where a final processor would be. I mean, it actually scores lower than the Z3770.
Aug 11, 2008
10,451
642
To be fair, Cherryview atom is the latest iteration of that chip, and is on 14nm. And I would hardly say atom is in its "infancy". More accurately is has just suffered severe neglect until the last couple of years.
That said though, I view all these comparisons of x86 and ARM directly with a grain of salt. I have always said it will be difficult for intel to compete directly with ARM on apps that dont use x86. They need to take advantage of the ability to run x86 in order to really compete. All the delays and somewhat (so far at least) disappointing performance of 14nm has not helped either.
TreVader
2,057
It is an impressive chip, especially considering how bad Exynos was just a year ago.
Nothingness
3,293
2,361
Atom has been with us since 2008. It is at least the second major micro architecture. Atom has been using three nodes without counting 14nm. At that time ARM had just announced Cortex-A9. Want to compare how Atom and ARM chips evolved since then and that despite Intel process advantage?
Please don't make the typical Intel fan answer that back then Intel wasn't serious ;)
2,012
ARM has really been impressive here. In the time it has taken to go from Silvermont to Airmont, ARM has put out:
- Cortex A57
- Cortex A17
- Cortex A53
TreVader
2,057
I wonder if the 14nm process that samsung is using is just that good. The 5433 was in Apple A7 territory in single thread even on 20nm, but this is equal to A8 in single and demolishes it in multicore.
That multicore score... wow. I was impressed with A8X multicore but this is just craaazy.
witeken
3,899
193
TIL a chip series from 2008 is still in its infancy.
It was originally an architecture from 2004 put on a small process node to make cheap and slow netbooks. It has been put on a 5 year release cadence by Paul Otellini, so the first iteration was 2013. Sure, it's got some platform changes and after netbooks it was put into tablets and smartphones, but nothing to write home about. What's worse, it that its successor was also meant for cheap laptops, and not so much for tablets.
You can't call platform that has a BOM delta and compensation associated with it and only 1 major silicon iteration mature.
Just look at how long it's token Nvidia to get a decent chip out of Tegra.
dawheat
3,132
93
Power consumption?
The Exynos 5433 power consumption was a bit better than the Snapdragon S805 from what I recall (or the same). I doubt it's going to be a huge issue for the 7420, especially if it's on a newer node.
2,012
Yep. Samsung looks like it has a good chip here.
2,012
This CherryView comparison is such a nonsense.
Best case Geekbench 3 score for the production Cherryview SoC 2.7GHz) is probably ~1100 ST score.
Still not really that great compared to an ARM A57 at 2GHz+.
That said, taking a single benchmark in isolation is never wise or really all that useful.
witeken
3,899
193
Airmont is a dual-issue architecture. No surprises there.
2,012
I think Intel really needs to up the ante with Goldmont. It's not enough for Intel even to be on par with the ARMy, especially given its vaunted process lead, it needs to be unequivocally better.
Right now, Silvermont performs at best on-par with an Exynos 5433 (3DMark Physics) and at worst well below it (Geekbench).
Now, don't get me wrong: Silvermont is a good architecture, but Intel delivered SoCs based on it quite late to market. Silvermont should have been an early-to-mid 2013 deal in both tablets and phones, and Intel should have had 14nm parts by mid-2014 if it truly wanted to capture the performance lead in mobile.
witeken
3,899
193
Do you think Goldmont has been delayed to 2016 to make some competitive changes?
2,012
The Goldmont is set in stone at this point; making modifications to a pre-existing core design is extremely difficult, so Intel had better hope it made the right architectural decisions there.
Where Intel can make modifications is on the SoC level. They could swap in other IPs, add in other IPs if those IP blocks are already done and validated.
Status
