Samsung DSR 3800 Problems...I dont know what to do
ManBearPig
9,173
Hi, i have a big problem with this satellite. It was working perfectly fine for a long time, and all the sudden, there is no sound. No one did anything to the wires as far as i can tell, so i dont know what the problem is. I checked the menu and obvious things, but i cant figure out what is wrong. i also have a couple other questons...
1)What is the best way to position this (we dont have enough wire, anywhere i can get more)?
2)Is this model very bad and old? If so, what should i get (something cheap please)?
3)i dont know how to upgrade firmware, it says i cannot when i try, but how can i?
4)Any other tips on this?
thanks tons
ManBearPig
9,173
No because there really isnt one. Its like free channels. Some are locked and those you buy, but some are broadcasted for free.
