- Mar 18, 2007
- 11,964
- 158
- 106
Your right.My 980 Pro has been fine for 2.5 years now. The issue was fixed with a firmware update in Dec, 2021. Long before it was ever announced.
The plain 980 is a newer model, but only PCIe 3. I never knew it had issues.
The 980 Pro should be considered a fine choice, especially now that it is so reasonably priced at many places. Just be sure to update the firmware and do backups (as always). The 990 Pro is even faster, but I personally feel that it is a bit too much $$ for the performance increase right now. Both are still good products that one could consider buying.
Ah yeah you are right, looks like just recently there are great sales on them as well. Almost 45% off. https://www.amazon.com/SAMSUNG-Internal-Expansion-MZ-V9P2T0B-AM/dp/B0BHJJ9Y77?th=1Your right but it is only $20 more.
Though that could make a huge difference if you buy 2 or more.
No, the reason for these prices is the tough economic environment. NAND prices are in free fall due to much lower than expected demand. Some of the companies producing NAND memory are taking nasty losses.I bet it is because of all the previous issues.
This is why the 980 Pro is now in direct competition with drives that were historically considered "value" or even "cheap" drives. The 990 Pro will stay slightly more expensive as the 980 Pro supply dries out, then it will probably take it's place. The competition is very fierce, and this summer is probably a good time to buy into more storage (as much as needed anyway).
