ordered it from dell.com
it was fine when i got it 2 days ago.
this morning i turned it on and everything is blurry. i've tried adjusting the contrast sharpness and everything else but the text is still very blurry.
anyone else had this problem?
i think you got a bad one. mine is only very slightly blurry the farmost left and right sides, but it looks like that's becuase of something to do with it being flat.
Degauss is the method of running a magnetic charge across the front of the picture tube. This is to straighten the gun beams. Might be worth a try, not familiar with these monitors.
Is there perhaps a sharpness control on the back of monitor?
