Hello,
I'm planning on buying a Samsung 850 Pro SSD as an external drive and lately a few questions have been nagging me about it.
1. Does this Samsung SSD use any kind of compression from the level of the controller and inside hardware, like SandForce-based SSD drives? I'm looking for a drive, that doesn't compress data at all.
2. If I don't do anything with the BIOS password and don't enable anything in the Samsung Magician Software, will the SSD always be accessible without any password, despite the encryption or even better, can I simply disable it? I don't mind the encryption (although I don't care about it either), but I also don't want it to suddenly lock up the drive, without my consent. So basically, I want to run the drive with no protection. Also I assume that I can use crypto-erase on the drive with a PSID if needed?
3. Will the Samsung Magician software recognize the drive if I connect it via a SATA to USB connector?
Thanks in advance.
Thanks in advance.
